BarryTurano
- Joined
- Oct 26, 2014
- 145
I got rid of my EFI system a while back. Put on a Quadra Jet. Put in a HEI Distributor. I was still having issues with bogging. Kept changing plugs finding some were fouled with fuel. Finally realized that the EFI pressurizes the fuel to a fine mist. Where as the carb does not. I went to a hotter plug that seems to have solved the problem. Put in NGK 2238 TR5 V-Power Plug. So far so good. Full rpm's where before I could not, would bog down after running for a while I would need to come off the throttle, then it would catch up. But I could not add throttle because it would bog again. Does not happen now. So by going to a carb go to a hotter plug.
