KenOverton
- Joined
- Jan 27, 2010
- 40
2 weeks ago I took my boat out and had an issue where after extended idling in a no-wake area, the motor would not accelerate, it would bog-down as if it was flooding out. After multiple attempts, and after sitting shut off for about 2 hours while fishing, the motor initially bogged-down and then accelerated fine, but was very touchy on throttle placement. If retarded 2 far, it would start bogging down, and if advanced would not respond until almost 3/4 full throttle then would accelerate okay all the wa to full throttle.
Back in November I used a full can of sea foam to remove any built up carbon, spraying in the carbs while running until I had a decent smoke cloud started, then let sit for half hour or so and running until hot again.
I thought that maybe carbon had plugged up the fuel recirculation, and I think my guess was correct. The screens on the cylinder drain covers was blocked by carbon. I cleaned the screens but I am confused on the particular set-up that I have.
Looking at pgs. 232 thru 234 of my Clymer manual shows that my motor should be set up like pg. 233. It is, except I do not have any check valves or any hoses to them (no.11 and 12), and there are no ports to install any check valves. I also do not have the tees on the cylinder drain covers, and my drain covers only have screens. There are no reed petals or related parts and the drain covers do not separate, they are more or less solid with only the necessary drain passages. Attached are pics.
If any can clarify
If any can clarify
