as long as your getting spark on all 4...i'd look toward a fuel problem....have you tried using a starting fluid yet?<br /><br />a standard answer here is have you done a spark check...compression check yet?
thanks,<br /> i got it running. but i can't figure out where<br />the water from the water pump is suppose to come<br />out. I want to make sure it is coming out so i don't burn it up.
Is there any water spraying out the exhaust relief holes on the back of the driveshaft housing?<br /><br />Most of the water will exit thru the exhaust.
