FORCE 120 NEEDS HELP
lonewolf5347
CAN ANYONE HELP ME WITH THIS PROBLEM.ENGINE IS FIRING ON NO 3@4 CYLINDER ONLY'1@2CYLINDER NO SPARK.CAN IT BE THE STATOR OR SWITCHBOX .ENGINE START UP WITH NO PROBLEMS
sony2001
Re: FORCE 120 NEEDS HELP
On the engine there is a plan of the electrics. The only part that services exclusively the cylinders 1 + 2 is the CD unit. I would start there.<br /><br />------------------
lonewolf5347
SONY WHAT IS THE CD UNIT @ WHERE IS IT LOCATED THANKS FOR THE REPLY
lonewolf5347
SONY IS THE CD UNIT THE COIL PACK FOR EACH SPARK PLUG? IF SO I CHANGE THE NO 3 CYLINDER WIRES TO THE NO 2 SPARK PLUG @ IT FIRED UP
sony2001
There are 2 CDunits that are wired to the four ignition coils. The CD unit is about the same size as an ignition coil,maybe black in colour. One feeds cyl 1+2 coils. The other feeds cyl 3+4 coils. With voltmeter x 1000,AC scale put red meter lead in orange CD module<br />lead. Crank engine a few seconds. Needle should move. Oh black meter lead to terminal ground.<br />Same check on red CD module wire going to #2 ignition coil. Crank and needle should move.<br /><br />------------------
lonewolf5347
ON THIS MOTOR THERE ARE 4 COILS ONE FOR EACH CYLINDER FOLLOW THE WIRES BACK to THE SWITCH BOX. FROM THE BOX TO THE STATOR; SO THE CD UNITS MUST BE IN THE SWITCH BOX? THAT ARE SEALED.SOMEONE TOLD ME THE SWITCHBOX ON THESE ENGING WERE MADE TO LAST A SHORT TIME ONLY.JUST ORDER ONE FROM FLA.AT THE COST OF170.00. ON LONG ISLAND THE COST IS 250.00 BIG DIFFERENCE. NO HURRY LOST ABOUT 4 WEEKS OF GOOD FISHING.HOPE TO GET THE BOAT IN THE WATER BY THE END OF THE MONTH . THANKS FOR THE REPLY
sony2001
You've got it. The book calls them CD unit and CD module. The trade call them switch boxes. That was cool. Now I understand more of how my own motor works!<br /><br />------------------
lonewolf5347
The part should be here by the 20 of this month shipped from fla. for your records if you have to purchase something for your motor check out this site he had the best price SEILER MARINE.I GET BACK TO YOU IN THE MIDDLE OF THE WEEK TO LET YOU KNOW HOW I MADE OUT lonewolf AND AGAIN THANKYOU FOR THE REPLY.
Hitman65
Lonewolf and Sony,<br />I work at a small marine inland and had a '97 120 Force that had spark but would not fire with the plugs in the cylinder. I ran the manual said to check the voltage at the coils. All 4 checked bad. Ordered the coils, swapped them no good still no fire with with plugs installed. So went to the next check and it said to trouble shoot the trigger switch, it checked good next it said to troubleshoot the stator. I guess they have had a problem with them as they have a service bulletin out and it changed the stator to a (red stator). We ordered the stator and installed it and ran like a champ. We think after much discussion at the shop that the coil broke down due to low voltage from the stator cause the coil to try to produce more with less. Any thoughts on this one??????
lonewolf5347
FIRST ? WHAT IS A RED STATOR.WHEN I CHANGE THE NO3 COIL WIRES TO THE NO 2 COIL IT FIRED UP. GOING WITH THE EASY JOB FIRST. AND DON'T HAVE ANY IDEA IN WHAT DETAILS IS TO REMOVE THE STATOR.ANY HELP
Hitman65
Actual Lonewolf, I dont think you had the same problem I had. I could not get this one to fire at all with the plugs installed. As for changing the stator really pretty easy. removed the 1 1/16" nut on the flywheel put the puller on it pulled the flywheel off and stator is attached with six allen screw on the top of the motor. also has four wires coming out to the switch box. thats it. took me all of 20 minutes to change and have it running. <br /><br /><br />As for the red stator it is a replacement the merc came out with for most of the Force engine line. It come with instructions for about 10 different motors and some different wiring harnesses to support the other motor types. I would say that it is an upgrade from the old stator only.<br /><br />Hitman.
lonewolf5347
HITMAN THANKS FOR THE REPLY LIKE I SAID GOING WITH THE EASY ONE FIRST WILL SEE WHAT HAPPENS. HAVE ANOTHER ? I LIKE TO HOOK UP A TACH. THE RECTCTIFER WIRE IS GREY THROUGH THE MAIN HARNESS DOES IT CHANGE IT COLOR TO GRAY WITH A BLACK STRIPE AT THE DASH PANEL
Hitman65
Not NORMALLY!<br />under normal situation the wire in a force/merc harness is gray for the tack signal. But i have seen a few different ideas. Its really hard to say though as I would have to see the harness. from there I could tell you. But if you dont have a plain gray coming out of the harness under the console gray with a stripe may very well be it.<br /><br /><br />Hope this helps,<br /><br />And let me know what you find on the CDI/Coils/Stator/trigger switch problem......<br /><br /><br />Hitman
lonewolf5347
by thursday i should get the part I post a message to let you know how i made out nice talking to you lonewolf
