I've got two questions about my 1989 125 HP Force on an 18' Wellcraft.<br /><br />1) The manual says the recommended RPM range is 4500-5500 RPM. However, at WOT mine only goes up to about 4000 RPM and the boat cruises at about 25 mph. I think it is the original prop, so it doesn't seem likely that is the problem. The engine runs and sounds fine all the way up to maximum speed.<br /><br />2) Occasionlly, when cranking the motor to start, it turns over for about 2 seconds and then stops cranking and just sort of hums. It usually ends up starting okay, but sometimes I have to work at it. Is this normal?
