Force 125 bogs after 10 minutes
Ldrive
Force 125 bogs down at full throttle after 10 minutes or so. Also won't always disengage to neutral. Help, life is such a mystery.
kev_79
Re: Force 125 bogs after 10 minutes
for the neutral prob, check and adjust cables. probabaly just on the verge of shifting, sometimes it will, sometimes it won't. As for the bogging, the only thing I can think of is trash. Either in the gas tank, or carb bowl. After you run for a while, it is picking up stirred up trash and blocking a jet or fuel flow. Good luck
