Hello forum,
I have a 1986 Force 125 hp engine. My lower unit would not go into forward all the way which ended up being the forward/reverse dog and gears. I re-milled the pockets square and re-assembled the lower unit just as it came apart. I noticed about .030" end play in the prop shaft. The book says not to be more than .010". I am in the process of making a new thrust bearing washer (hardened and ground tool steel) to take up the end play. I am shooting for zero end play, and not to tight either.
As I started to put the pinion shaft back in, with a new crush ring, the shaft has quite a bit of end play too. This dont seem right to me.
I can see the bearing cage is moving which is creating the end play. There is a ring on the bearing cage that is loose from the cage. This ring is where the crush ring is pushing on. With this ring not being part of the cage, the crush ring really isnt loading the bearing. It is accually pushing onto the bearing rollers! This cant be good can it? How is this set up supposed to work?
Thanks!
Thanks!
