So to preface this, I am very new to out board motors.
So that said I bout a fishing boat with a force 125. It has a couple of problems first was the lack of water movement through the motor so I ordered a impeller re-build kit. It also had a broken skag so I figured I would get that fixed while I had the L/U off. Well I got ahead of my self and pulled the bottom shift linkage pin that screws in instead of the drain plug.
Now the L/U is at the shop getting repaired and I am worried that i screwed something up by removing the lower pin. How hard is it to line up? It screwed back in but now that I think about it the shift rod moved very freely.
Any help is appreciated.
Thanks,
Ben
Thanks,
Ben
