foxtrotboss
- Joined
- Jul 25, 2009
- 46
I have a really good question I think and I haven't found the answer in the archieves.
I have a 1986 force 125, and can you believe this #3 piston ring and piston are broke. Is there a way to replace one single piston and rings w/o removing the powerhead? I do plan on doing a complete overhaul/reman on the motor this winter but for now its summertime I want to go boating
I have found many rebuilt power heads but my they are more than I want to spend right now. I just want to fish and pull the kids tubes.
I know the Force 125 has this problem with factory rings and pistons. I will be replacing with wiseco stuff. But I think this motor is not that bad it is simple and basic and parts are still out there. I would though like to be running on four cylinders though LOL.
For those who want to know more info #1 - 130 psi #2-120 psi #3- 75 psi #4-130 psi. #2 is scored definately but no broken stuff I can tell yet, so I think the previous owner did what I am thinking about. #3 you can see the ring coming to the top of the piston. If you are familar with force problems you know what I mean.
I have a manual on the way from Barnes and Nobles but not here yet. If I have to pull the power head chances are that it will be complete overhaul time since it is off. there went a week or two of boating
Thank you for your input
Scott
Scott
