Boatdrinks
- Joined
- Jan 9, 2005
- 105
Guys, my dad has a 1988 Force 125 that runs good at WOT but loads up at lower throttle settings. The plugs are always wet and the fumes at lower throttle settings are terrible! (raw fuel) He has checked the carbs for debris, float height and any worn, damaged needles, seats or jets. All appears to be ok. There are no visible leaks.
Do you have any ideas? He picked this up used a little while ago so we are not sure what the problem could be. Also...you guys that are reading this...does anybody have a schematic for the trim/tilt valve body? Somebody took his apart before he got it and something is not put back in right or missing. Perhaps a spring or check valve in the wrong place. We can't seem to find a schematic for the valve body anywhere! No leaks and the cylinders appear to be in good shape too. Both the trim and tilt cylinders leak down...so it must be in the valve body. Any help would be appreciated guys....thanks!
