Force 125 sputter?
rudedude
I figured I would try and get some input from this Forum.
My Force 125 has run fantastic over the years. I took the boat out into the Gulf of Mexico yesterday and ran great for about 10 miles at 3/4 throttle, about the time I got to the fishing wreck it started to spudder and act like it wanted to die, I cut back to 1/2 throttle so I could lisen to the thing and it picked back up, I turned back and came back up to running speed and it ran fine so I headed for the shipping channel just in case it went down on me. I stoped at another spot and fished for 4 hrs( got a couple real nice redfish) I decided to run back in because it was way to hot out there ( the bilge pump came on and pumped the sweat out of the bilge, Time to go LOL)
I started it and it sounded like a miss in it, I came up and it started running just fine again and ran that way until I reached the jetty, it sounded like a miss again and then ran just fine to the boat ramp.
Could the oil mix be too rich? I pulled the plugs today and thay had a very little oil fouling on them, it ran just fine for the flush( about 20 mins or so).
I was thinking I may have had too much oil in the tank, anyone have any Ideas on what it could be? Wont go out in the Gulf if I dont trust the motor, putting the kicker on tomarrow.
Frank Acampora
Re: Force 125 sputter?
Sounds like it could be periodically starving for fuel. Check the fuel pump diaphragm and Check the screen on the fuel pump. If you have one, check that the filter is not clogged. Check to be sure all fuel lines are open and free flowing and the quick-connects are clean (if you have them)
rudedude
The fuel lines are new and is the filter. All lines are clamp type and do not seem to leak. I will pull the pump and screen in the morning. Didnt even think of it , The motor has set for about 2 years but was drain of all fuel , from the tank to the carbs and all lines to motor. Thanks for the quick reply.
rudedude
Screen was clean and I did't see any damage on the diaphfragm.
rudedude
It will be replaced, dont want to take it off again in a few weeks. Got too much fishing to do.
rudedude
I want to thank y'all for your input.
THANK YOU
