force 125hp 88
galillo
Hi
I just buy a bayliner capri 19' with a Force 125HP 1988, i don't have idea how much water how to come out for the pin holes because most of the water come out from the exhaust and only a little bit for the holes on the middle, i read alot about the pressure valve on the water maniful left side of the motor but I just opened and could't find any thing weird, this is normal on this motor I buy the book to fix those motors and nothing come about this pressure valve. any recomendations.
Thanks.
Frank Acampora
Re: force 125hp 88
There is no water pressure relief valve on that engine. Only a cast blind hole that you can insert your finger into.
Como su describe el agua esta bien. Mucho del exhaust y menos de las "Idle Relief Holes"
Cuando la barca esta "on plane" un poco mas agua sale de las Idle relief, pero 90% o mas sale con exhaust.
galillo
Re: force 125hp 88
Thanks Frank that was my concern i was expecting to see a lot of pressure at not speed for that holes,
Thanks again.
Frank Acampora
Re: force 125hp 88
No problem! You gave me an excuse to practice a little of my seldom used Spanish.
