Force 125hp Prop
Frank Acampora
Some Mercury props will fit. The small gearcase 90 HP used prop that will fit into the Force gearcase. Regular mercury props have a bigger hub That will rub against the Force gearcase. If you have a single exhaust and you cut off the flange that plugs into the gearcase then the props will fit.
I hate to say it but why don't you go on ebay and search Chrysler Force props. There are usually a couple of used ones there.
jerryjerry05
The Force works best with a Force prop.
Frank said it.Look on Fle-bay. even Craigslist.
Or contact Michigan propeller they can sell you exactly what you need.
What's wrong with the one you have? Get it redone?
Beware of used stuff.
I've been using my props for YEARS!!! One day I was greasing the shafts and spun the prop after I was done.
I noticed the prop had a wobble????
No idea how long it was wobblin.
The wobble could have ruined the bearings and carrier.
I had bought it used years ago. I don't know if it was bad when I bought it or not???
Luckily I had another spare also used but this one doesn't wobble.
pnwboat
That prop will not fit unless you do as Frank mentioned. It's for a 4 1/4" diameter hub gearcase. The older Force hub gear cases are 4".
KScott78
Thanks for the replies! I will order one online, however I needed something for this weekend and shipping can take about two weeks. The one I have is in veery rough shape. It might work but would have alot of vibration.
