So I previously posted a thread about my force bogging out and got a lot of help, unfortunately none of it panned out. I really need some help, I am fairly good with my hands but have little tech. knowledge, especially about marine engines, and if I have to take this to a mech. I may not be able to put this boat on the water this season. It is an early 80's force 125 hp outboard, the compression has been checked and is good, as is the propeller hub. When it gets in the water it idles well and moves slowly without much trouble, however when I throttle up, the carbs are open wide and there is good fuel flow into the carbs. All of the plugs have strong spark and the engine doesn't have any rattles that I can hear. I do think the lower unit is leaking a little as I have seen oil coming out the water output and the screw on the front of the lower unit (not the fill or the vent but the one everyone says not to mess with?) and when I changed the oil in it there was something that might have been water. I really dont know what else to look for, I have an engine manuel but there isnt any trouble shooting section. Please if you have any ideas let me know. Thanks so much.
