arriva2001
- Joined
- Feb 15, 2015
- 64
Hi
last summer I replaced the wiring on my trim motor because a short in it caused the wire insulation and relays to melt (yikes!).
anyway, there appears to be a short within the motor itself now because it’s become very unreliable whether or not the motor will activate when I press the button. Sometimes it works. Sometimes not. So I want to replace it.
my questions: I bought a replacement motor and plan to install it this weekend.
1. Should engine be up or down when I remove the old trim motor, or does it matter?
2. How do I avoid a giant mess of hydraulic fluid everywhere, or is it just inevitable that it will pour out when I remove it.
3. What should I use to reseal the new motor? Gasket and Loctite? Or just gasket? Is there a spec for torquing the bolts?
4. How much fluid do I need to add back, and do I do that with motor up or down?
thanks in advance for any help!!
