Force 150 won't tilt/trim up
Quick Cal
Now among the other problem's I'm having [see other thread], I'm going along today and notice my motor won't trim up. I thought it was just a bad connection on the throttle. But if I keep messing with it, it will work. When I got it out of the water, I discovered I had the same problem at all 3 place's I have trim button's. Front/rear/throttle. I checked all wire connection's, everything seem's fine. This motor look's brand new. I could hear the relay's clicking. I put a new relay on the up, still has the same problem. If I keep messing with it, hitting the up and down button's, it will work just fine.<br /><br />A friend told me it's the selonoid. But from what I could see, it doesn't look like the wire's go to the starter selonoid. But I'll have to tear into it to see for sure.<br /><br />Any idea's. Thank's, Cal<br /><br />Also, is there any forum's for Quantum boat's. Thank's
zindale
Re: Force 150 won't tilt/trim up
howdy i have the same exact boat as yours with the running prob except mine bumps at 22oo rpms. my trim was not going up was a bad relay replaced it and works great. u can try swaping relays. and it does not wire to the sol. at least not on mine. my has run bad since ive got it havent had it up to speed cept the first time i took it out.
zindale
also found out that boat was made by maxum same folks who make bayliner, hop that helps
roscoe
Quick Cal, try connecting the trim motor wires directly to the battery with jumper cables.
Quick Cal
I read in the manual that if it will go in one direction and not the other, the problem is not the motor.<br /><br />What's really strange is that the new relay did not fix it. However, I switched the relay's around, and now all SEEM'S well. Probly until I get it in the water that is,,,,lol. Maybe the problem was just a loose conection. Who know's. <br /><br />Now I'm going back out to push the button's about another million time's. Cal
