Force 1996 120 hp binding when rotated
Jettaway
Turning the flywheel with all plugs removed engine binds 180 degrees apart, also 15 psi compression on #1 cylinder, new to the engine and don't want to throw good money after bad motor, did not try to run engine concerned ore damage may take place, boat and trailer were a good deal.
jerryjerry05
Re: Force 1996 120 hp binding when rotated
Remove the head and check for damage.J
