Force 50 1987 spring gasket found around drive shaft
I removed my gearcase to replace the lower shift rode seal because of shifting problems. When I removed the gearcase I found a metal spring seal around drive shaft. This metal spring seal was on the outside of the water pump. Is this seal part of the lower crankshaft seal? Is it easy to replace.
