Appreciate any advice on the reason why my 1988 Force 50 will only run to 4200 RPM at full throttle. It starts perfectly, runs smoothly and blasts out of the hole but will not rev past 4200 RPM. Was 4000 RPM until I adjusted the trim with some well placed bolts taking Franks advice until I can repair the tilt and trim.
I have pumped the primer bulb furiously at full throttle but no difference.
I have checked the carb butterfly position with the engine off and the throttle pressed all the way to stop in the forward position and I am NOT getting a horizontal butterfly. it's about 75% open. Now the confusion.
Should you do the adjustments on the carb linkage with the forward control set to full throttle OR move the mechanism on the timing tower to full throttle and then check for horizontal butterfly?? Does this make any difference? I haven't peered down the carby at full throttle with iPhone torch on the water and don't really want to
Will the engine running alter the mechanism and enable the last 25% of butterfly movement?
Is this likely to be the issue? I don't know what the prop is. Boat is nearly 16 foot and maybe underpowered with the little 50? It doesn't labour up to the current 4200 RPM, accelerates hard but that's it when get to that RPM. Many times I try and push the throttle forward and find its already on the stop. I haven't done a compression test but I guess its possible its low but runs so sweet and strong to the current limit.
I haven't cleaned the carby out either and am not sure I fancy pulling it apart and finding I need gaskets or parts that are notoriously hard to find in the land down under. Appreciate any help.
