Force 50hp, 1988, 507Y8D
Using my DVA meter I determined I had a bad trigger. Changed that, had to make some throttle cable adjustments and throttle linkage adjustments to get it to run right since it was running on 1 cylinder for so long. Now I have spark on all cylinders but it is jumping/coughing every 10 seconds or so. It does this in neutral and in gear. I have included a link to a short photobucket video showing what it is doing.
Note on the video that the first "cough" occurs at 10 seconds in, then at 22 seconds, then about 39 seconds.
I have set the idle mix according to the specifications in the Force factory manual.
Photobucket link to video:
http://s298.photobucket.com/albums/mm270/markh28/Misc Boat/?action=view¤t=VID00004.mp4
