Hello, I have a 1987 14ft Bayliner with a Force 50 with a serial # of 1411 and a model # of 507X7c. When I first ran the boat it was a charm. I now have the following problem: The boat will only do 5mph. I have replaced the plugs and have done a spark test which showed good spark from the coil, but after running motor at 5mph around the lake (fishing of course)and I pull the top plug it is wet and appears not to be firing. The motor sounds good at idle and revs fine in nuetral but when engaging to forward it has no power. Any suggestions?
