Force 50 ID please
68couper
I picked up a Force 50 today. Previous guy had no information. He gutted a pontoon and had this sitting in the shed. So I spent 7 hours on the road going to Michigan to pick up something with an unknown running situation. Sooo, tag appears to be stripped off the unit. I found where the sticker should have been. So I got a bunch of pictures. First I have to get this thing on a stand and I'm going to run compression on it, what is a normal reading ? I'm thinking it will need impeller gear case oil, fuel pump diaphragms, fuel lines, and a carb clean. Going to need some experience on this one . Any coaching along the lines of that is more than welcome.
tg3690
I would add a spark test to your list......spark should jump a 3/8 inch gap.
jerryjerry05
The name Force was used from 1984 to 1999
Pics: you'll need 5 posts before you can use the "add pics function" on here. Look up photo addition sites like Photo shop or something along those lines.
