force 50 problem,again
spitz666
ok i think i know the problem, while messing w/ the prop i noticed that the exhaust vent cover is missing i believe this is the problem.exhaust is pushing away the water so prop has no thrust. could this be it? anyone know where i can locate such an item or if i can rig it somehow.
roscoe
Re: force 50 problem,again
You can try the Mercury parts web site.<br /><br /> http://www.mercurypartsexpress.com/PartsExpress/ProductSelection/ServiceParts/sphome.asp?CID= <br /><br />You need to type in the serial number of the motor. Select the gearcase option when it comes up. You are looking for an "exhaust snout."<br /><br />Also, it is best to continue your postings on the same thread that you have been using. Every time you start a new thread, you loose information that may be of value in troubleshooting your problem. This current posting gives no reference as to what the original problem or symptoms were, or what has been tried to diagnose and remedy the situation.
