Agree on slipping hub. If you didn't mark it from the brass spline all the way out to the exterior of the barrel casting....the whole shebang, your line is worthless. On what they did for a test, ask them. Obviously you won't get the correct answer in a run tub/barrel, especially if you put a test prop on it to get to WOT RPMs without emptying the tub.
