Force 50 stuck in forward
pepescot
the shifting issue I have is now narrowed down. Controller and all cables/linkage working fine. Pulled the upper shaft covers off and all works as its should but regardless of where I set control ( forward, neutral or reverse ) prop remains engaged in forward. Looking for input on what to expect when I pull lower unit off.
DAN M VAGOS
Re: Force 50 stuck in forward
Did you drain the lower oil and remove the linkage by mistake.
pepescot
only have the boat a month or so. Have not touched anything other than removing the engine cover and the upper side pieces directly under the motor.
