Force 50hp
craigo114
hey hi guys hope someone can help, i have a force 50, but just recentley ive noticed a small hole at the back of a fin screw, and when i tilt the engine out of the water, water drains from this hole, also ive notice considerably less water being pushed trough the outlet when running. is this newly found hole the problem, and is water being pusher through it., insted of the proper outlet holes ?<br />Regards<br />Craigo
roscoe
Re: Force 50hp
Welcome back.<br /><br /><br />
Originally posted by greece:<br /> a small hole at the back of a fin screw,
Where is this hole located?<br />Add a photo if you can.<br />What is a "fin screw?"<br /><br />If you haven't replaced the waterpump impeller since you purchased this motor, you should.
eurolarva
Re: Force 50hp
Fin screw as in Skeg? Is this near the drain and fill screws or the pivot screw also down by the skeg?
