I have a 1991 Force 70. I just bought it and had it tuned up, had new seals put in the lower unit, and ran it on the hose. I noticed the exhaust water was cloudy white.....is this normal? I've never seen that before. I figured either it's because that's normal and I just never recognized it before, the gas is old and should be replaced with fresh stuff, or that is not normal and it needs attention. But I have noticed the motor runs very strong. Another problem I have noticed is that since I had the new seals (and water pump) done in the lower unit, there seems to be a small amount of oil-like sludge coming out from where the back of the prop meets the lower unit housing. It is not gear lube, it is like black oil, with a smell to. My mechanic said it's just run-off from the exhaust system and I shouldn't worry about it......you guys are the experts, SHOULD I BE WORRIED ABOUT THAT OR THE WHITE CLOUDY EXHAUST WATER?? If you can, please e-mail me in addition to just responding, I plan on taking the boat out today for my maiden voyage! My e-mail is RadioguyJ@aol.com. RadioguyJ@aol.com
