Force 70hp general question
atengnr
Question about the 3 cylinder, single carb force engine. Does this design lead to variable oil delivery to the cylinders and early failure? If so what is best to prevent this?
thanks
jerryjerry05
I never liked the 3 cyl. with only one carb :(
Seems the fuel mix doesn't always get to the top cyl.
Running your oil a t 40-1 might make it live longer.
But you'll need to change the plugs more and do a decarb more often.
atengnr
Thanks. So youve seen lots of these motors wear out on too cylinder early?
jerryjerry05
Not lots but they seem to loose the top cyl. more than a motor with 3 carbs.???
atengnr
These typically sudden failures or just premature worn cylinder bore?
jerryjerry05
From what I understand, the top cyl doesn't get the lubrication and if the oil's
not the low/no ash it carbon's the rings and premature failure happens.
The better the oil the lower the chance.
Using a bit more oil and doing a de-carb more often can help??
No matter the brand carbon forms, so a regular de-carb will help.
