baboon bum
- Joined
- Mar 7, 2004
- 31
While out on the loch my battery went flat,i had a spare so put it in place and she started 1st time however the next time i tried it made a screeching noise,i took the cover off and noticed that at the top of the starter the nut had worked loose and the return spring had fallen off the spindle i replaced the spring and the nut but when i turn it over the small cog that throws up to engage the flywheel just throws up and wont turn the engine the spindle appears to be well greased any ideas
