Jeffromxer
- Joined
- Jun 12, 2014
- 21
I have a 97 Force 75ELPT on a 20 foot pontoon I just bought. It ran good when I got it. However max RPMs were only 4500. The prop was chewed up so I replaced it and viola 5200 and running well. Not for long though. Next time out I throttled it up. It ran good to 5200 RPM for a few seconds and then dropped to 4500. Ever since then It will not idle and will not reach maximum RPM. I pulled the cover to see what was going on and fuel was pouring out of the throat of the carb. I pulled the carb and cleaned it and made sure the float was adjusted and needle was seating. I believe it is. I can pump the ball and it gets hard and holds pressure. I also noticed black debris in the fuel filter so I replaced it along with the hose from the tank to the primer line. I still have very low idle and stalling and lack of RPMs that I believe is due to running rich. However it runs great from 1000 to 4500 RPM. Here is the weird part. If I pull the fuel line from the carb bowl to the Fuel Enrichment Valve I can get 5200 RPM and smooth running but still no idle. Does this engine open the FEV at WOT? Any ideas would be greatly appreciated. Thanks
