I am hoping that someone can help me. On my Force outboard motor, MANUAL TILT,( MODEL NO: 856X7b, SERIAL NO: 4132. The bracket for reverse thrust will not lock in place, even with the engage/disengage switch locked on at the back of the motor, and the engine flies out of the water in reverse :+(<br />I can only assume that some cable / latch / rod has snapped off. I would be grateful for any info you can supply and where i can obtain parts from. <br />Is it an easy job to repair myself ?? Expensive ?<br />Cheers, Steve
