Ive got a 1987 85 horse force motor, When your in the water if you put the motor in reverse and give it a good amount of throttle the motor picks up out of the water like its pulling the rams out. the tilt and trim both work perfectly i can put it on the trailer and tilt it all the way up and over a weeks time it wont fall an inch. If your driving in forward this problem doesnt happen. I know the upper seal on the left side ram is seeping a very very very small amount of fluid, i leave it on my drive way and in a weeks time it may drip one lonesome drop, i havent had to add fluid to it since ive owned it.
