fishthebay
- Joined
- Aug 17, 2001
- 180
Hello:<br /><br />Fired the boat up for the first time today this season. Its an 85HP 1987 Force.<br /><br />It took about a minute or so for the water to start coming out of the tell-tale. Once it did, it was a very good flow.<br /><br />I did notice however that before the water starting coming out, the powerhead got hot. I assume it took a minute or so for the thermostat to open.<br /><br />First question - Is this normal for Force Outboards?<br /><br />Second Question - I notice always notice that water immediately flows good out of the tell-tale once the motor is started in the water, while on a hose it takes about a minute. Is this normal?<br /><br />3rd Question - How long should I wait to cut the key off is no water is coming out of the tell-tale when started with a hose? Like I said, it sometimes takes a minute, but the powerhead gets hot and then if starts coming out in a good stream and everything cools quickly.<br /><br />Final Question-<br /><br />How hard is it to replace the waterpump and Theromostat myself? I have never done it on my own, but took it to a mechanic 2 years ago to have it done. I found a good mobil mechanic that's cheap. What should this cost me for a mechanic to do it, or should I attempt it myself?<br /><br />Thanks guys.
