force 9.9 hp how much gear case oil is require to fill?
munjue
as the title suggests, its an early 90's force 9.9,
do you fill the oil from the drain till it comes out of the vent?
or is this the wrong way for this type of outboard?
roscoe
Re: force 9.9 hp how much gear case oil is require to fill?
Yes fill from the bottom, forcing the air out the top, requires 5 ounces of lube.
