Force 90 HP model designation
rottenray6402
Ensign
I am learning a tremdous amount aabout Force outboards in this forum however I have a question regarding my 90hp. It is a 1990 model and I have seen listings for a 90L and presumably a regular 90. Can anyone tell me if there are several different models of 90s that year and if so how to tell the difference? Thanks!
roscoe
Re: Force 90 HP model designation
90L refers to an L-drive, which is an outboard powerhead, mounted inside the boat like an inboard, and connected to an oitdrive system thru the transom.<br /><br />Here is a list of the different 1990 90hp model.<br />While they are basically the same, they may have different components, ignition systems, carbs, pistons, etc.<br /><br />90hp 1990 l-drive<br />90LD90A<br /><br />90 H.P. (1990 L-DRIVE) <br />90LD90C<br /><br />90 H.P. (1990) <br />903F90A<br /><br />90 H.P. (1990) <br />903F90B<br /><br />90 H.P. (1990) <br />903F90C<br /><br />90 H.P. (1990) <br />903X90A<br /><br />90 H.P. (1990) <br />903X90B<br /><br />90 H.P. (1990) <br />903X90C<br /><br />90 H.P. (1990) <br />906A90A<br /><br />90 H.P. (1990) <br />906A90B<br /><br />90 H.P. (1990) <br />906A90C<br /><br />90 H.P. (1990) <br />906F90A<br /><br />90 H.P. (1990) <br />906F90B<br /><br />90 H.P. (1990) <br />906F90C<br /><br />90 H.P. (1990) <br />906X90A<br /><br />90 H.P. (1990) <br />906X90B<br /><br />90 H.P. (1990) <br />906X90C<br /><br />90 H.P. (1990) <br />908F90A<br /><br />90 H.P. (1990) <br />908F90B<br /><br />90 H.P. (1990) <br />908F90C<br /><br />90 H.P. (1990) <br />908X90A<br /><br />90 H.P. (1990) <br />908X90B<br /><br />90 H.P. (1990) <br />908X90C
rottenray6402
Ensign
Admiral Roscoe, Thank you very much for this information. It is most helpful!
mistermatt
Any idea where one might find (buy) a Wiring Diagram and perhaps a Manual for these engines? I have a 90LD90C.
1990 Bayliner Capri (Open Bow)
90 HP L-Drive Force
2-stroke
3-cylinder
roscoe
factory manuals show up on ebay from time to time.
Otherwise, your best bet is a Clymer Force repair manual, available on ebay or many other web sites.
mistermatt
Thank you for the info! I will check eBay.
