Hello All,<br /><br /> Here I go again. I was raising my Outboard and the power stopped. I checked everything and it looked good but hit the button - up or down - dead. I tried bumping the starter (as I am in the process of rebuilding the engine) and nothing. I played with the shifter (even though that has nothing to do with the tilt motor I thought it wouldn't hurt) and still nothing (start or tilt). I have checked the 20 amp fuse - it has fire on both sides - and I popped the relays (2) and they have fire to the red wires coming in. Is it possible that one or both have gone bad??<br /><br /> This is the 1997 90 Hp FORCE that ran hot and scored the bottom cylinder. I have the head off - the prop off - the lower unit loose - temp sensor out of the head. <br /> <br /> The unit lost power before I started to work on the lower unit. I have used a booster and charged the battery - still no go.<br /><br /> Any ideas will be greatly appreciated.
