Re: Force 90HP '92 won't start
Roscoe,<br /><br />Thanks for the reply. I would never call myself and expert but I think I can get by. I've done the basic outboard won't start procedure. compression, fuel and spark good <br /><br />Is this a new problem that just popped up? New, engine was serviced last year and ran fine last year. two years ago replaced impeller<br />Have you had the motor long or is it new to you? had the engine since 1995<br />Has the motor ever run properly? yes, but it has had issues. replaced stator in 98, had fuel pump replaced in 2000.<br /><br />Was the motor in the water when you started it?Yes, boat is on the water, engine in water<br />It should have been, as the engine needs the water to cool it.<br />If it wasn't in water, then you probably overheated it and caused seriouse damage.<br /><br />Ran it at 3000 rpm -- ?<br />Was this in water, in gear? or neutral? in water in neutral at the dock. I actually got it to start for a minute, which makes me think I can get it running. and like I said if I put a littel fuel in the cylinder behind the spark plug I get it to fire but won't run.<br /><br />If fuel is coming out of the hose from the fuel pump to the carbs could anything cause it to not fire if compression and spark are good? maybe there is water in the carb bowls. I'll be honest I can't check everything because it is in water and it is hard to work on.<br /><br />coolant water can enter the cylinders from a blown head gasket or the exhaust manifold. If it overheated, it likely blew the gasket, or worse. <br /><br />I'm leaning towards a head gasket after reading the clymer manual a little more. It is on the water so I don't want to mess with taking it off. I was hoping to get it to run so I could get it on the trailer correctly. It is a 24 ft pontoon and hard to get on the trailer without power.<br /><br />I've never seen this liquid beading on the spark plugs before. I assume it has to be water, it looks clear. I hooked it up to a portabel tank with known good fuel just to make sure it wasn't a sour fuel problem,<br /><br />Any help is appreciated.<br /><br />Three basics needed for an engine to run:<br />Gas to cylinders - Compression in cylinders - Spark<br />Check for gas to cylinders<br />Check compression<br />Check spark<br /><br />What is your starting procedure? pump primer bulb, turn on battery, lower unit into water, turn ignition.<br /><br /><br />Any thoughts would be helpful
