Force 90hp CFI
mowerman1975
I have a force 90hp CFI I think it a 1990. I have no spark. I have tested key switcots good. I have test the wire to the motor it’s good. I pulled fly wheel and clean stator from rust on the ends. It meters fine. I need to know how to test the tregger. It has 6 leads. 2 are marked 1, 2 more marked 2, and other 2 marked 3. How do you test it? Reason for thinking my issue is. Last year when on water I can rip around the lake. I would shut down and fish. Start back up and would run, when I put in to gear and go it would die. Now I have no spark at all.
Nordin
You have to troubleshoot with a VOM or even better a multimeter with a DVA adapter.
Measure the output voltage from the stator that charge the CD boxes and output voltage from triggers.
Outboardignitiondotcom has troubleshoot chart for you engine.
