Re: Force 95xr fuel or spark?
Adjust idling in Forward to achieve best idle speed, then further open each screw 1/8 turn. Test acceleration from idle, any slightest hesitation, bog, lean cough, then further open mixture screws 1/16 turn, repeat acceleration test until all traces of hesitation are gone.
Fuel tank Dip tubes can have a screen over the end or fiberous material inside, either can clog with sediment, trash, whatever, and restrict WOT fuel flow.
Fuel lines HAVE been known to be restricted by too tight a zip tie holding the hose alongside a wiring harness.
ANY restriction can limit WOT performance, too great a restriction and the upper cyl's start burning lean enough to melt the piston.
