jerryjerry05
- Joined
- May 7, 2008
- 18,158
This is to let you know that you can have a blown headgasket and still have 150#compression on all three cylinders.
I was out the other day and my port motor started missing. I thought maybe my pack went bad or worse(always thinking the worst).I get back and start testing.I always do a comp test first. It tested 150 all three cyl. I changed plugs and it seemed to run better.There was a small amount of moisture in the bottom cylinder.
I went out and it started missing again. At home again I pulled the head and sure enough the head gasket was bad.
WE went out yesterday and not a problem.Jerry
