Force clamp screw bolt thread size?
jerryjerry05
I think it's: 1/2x 24
Got a Granger store or a hardware store? they can help with the size..
Nordin
I believe that one is larger.
5/8 x11 UNC or maybe 3/4 x ?.
I know that smal OMC engines (5,5Hp Evinrude 1963) has screw diameter size 5/8 and 11 threads UNC an in.
I have just restored one that missed both screw clamp.
slimmer57
From what I can measure is 3/4 but I don’t know the threads I had to drill it out
3/4" threads are most likely 3/4-10
Just to make sure we're talking the same thing, a 5/8 bolt will have a 3/4 hex head
Nordin
I am talking about the bolt diameter (threads) not the head size.
Do not know the pitch of the threads but I think Scott Danforth is right.
Do not know if it is UNC or UNF, but know that earlier Chryslers had both UNC and UNF depending on year.
airshot
Thread pitch gages are cheap, most good hardware stores carry them. Just match the threads and read the pitch.
3/4-16 is UNF. use a tape measure, measure out 1" and count threads.
brodmann
Go to any ACE hardware store. They'll have a thread gauge.. Bolts and nuts mounted to a board where you can screw yours in until you find the one that fits.
jerryjerry05
If you look at the pics???? You'll see there is no regular head, it's been modified to accept the handle.
Some are cut down to fit a 1/2" socket.
Also it's a fine thread, 1/2X 16 is too thick, that's why its a 24 or close to that.
