Force controls
burt_066
Hi:<br /> I have a mid 90s 90HP Force O/B and I need a set of controls. Must it be Force controls or can I use Mercury or Chrysler. Thanks Bobby...
imported_bjs
Re: Force controls
you might try quicksilver products they work on my boat but its newer.might be worth a try.good luck. :) :) :)
jastacey
Re: Force controls
What kind of Boat, on Bayliners, they came with Teleflex/Morse controls, with a seperate key switch/choke control, on the dash, anyways one could make any control box work with universal cables & adapters.... but it would cost some $$$$
Tom Formosa
Re: Force controls
Hi,<br />I have a Quicksilver control unit operating a 40hp Force outboard. Is there someway I can get an e-mailed drawing of the interior of the unit. I think I have something hooked up incorrectly. The lift throttle does not engage to cable and the shift lever travels too far before operation kicks in.<br />Thank you
roscoe
Re: Force controls
Welcome Decaf.<br /><br />Several models of Quicksilver controls out there, 2000, 3000, etc.<br />Need to know model and style. Any Mercury dealer should be able to order an installation manual for you, if you provide them with the model.
imported_bjs
Re: Force controls
florida guy maybe you need to adj.the cables.mine kind of sim.to what your saying i had to install a new cable now it works good remember when you shift do fast and firm.the throttle is sloppy on my baot to might normal.
imported_bjs
Re: Force controls
florida guy maybe you need to adj.the cables.mine kind of sim.to what your saying i had to install a new cable now it works good remember when you shift do fast and firm.the throttle is sloppy on my boat to might be normal.
imported_LakeRunner
Re: Force controls
I have a mid 90's 70HP and it's rigged to Quicksilver 3000. It sounds like you may need to get it adjusted. I had mine recalibrated and my shifting is smooth and quick. It did have a little drag before.I think I have a manual for it. email me at revans1@nc.rr.com if you need to see the instructions. The marina did the calibration for me so all I had to do is mount it.
