I just replaced the water pump in my 86 85 Force and it worked fine. The trouble is that now the boat won't get into forward. It makes a ratcheting sound and occasional lunges forward. The propeller seems to be moving all the time. In searching the archves, it appears that the shift linkage is off, or possibly the shift seal is bad. I can probably fix that (help is appreciated on this too though) , but I have a more pressing problem - the boat is stuck (safely) on the lake tonight. Is it possible to manually force it into gear just so that I can limp back to the dock without causing damage to the motor? I may be able to get someone to tow me, but the boat is in a remote part of the lake.
