Force tilt lock lever
spserg
Hello all, so I spent the weekend pulling my entire TT assembly to install new o-rings. In addition, I pulled the valve body for replacement. As luck would have it, all 5 of the trim bolts holding the piston snapped. LUCKILY, I have a spare motor for parts, which were in fantastic condition. One question, my donor motor has the manual tilt lock lever-but the motor I am working on does not. All of the threaded holes are there, but no lever or guide. I have looked all over and have seen some references to there not being the manual lock on motor with factory installed TT. Even though its all factory, I think the donor motor may have been a retrofit unit (no relays under motor cover). Can someone please confirm that there is no lock lever on power TT installed systems?
spserg
Thank you for clearing that up. Probably confirms my hunch that it was an add on to my parts motor.
