Re: Force
Turn ...AWAY.<br /><br />Unless you are willing to learn about outboards, tinker, diagnose, and repair them. They are prone to a wide variety of problems.<br /><br />Now, IF, you can get it dirt cheap ($500), are putting it on a small light boat, don't mind letting the boat sit for weeks on end while repairs are made, and are man/critter enough to take the jeers and snubs from fellow boaters, and you are able to test run and have a mechanic test the engine before ANY money changes hands, then go for it. <br /><br />If anything doesn't work, or if performance is not great, or if compression is low, or if tilt and trim has problems, then run the other direction.
