Ayuh,..... They clamp the carb down, without leaks,..??I have pulled my manifold and took the carb off. Put carb bolts back in and snugged them up. 1 bolt goes all the way through and the rest don't. Doesn't seem right to me
The thread on the bolt mashed up against the thread in the manifold should negate any path for air to enter into the intake stream.Just found it strange when I saw one go all the way through
I have the same thing on my '65 GTO some of the holes for the carb studs go into the manifold runners. Have absolutely no issue I just put some put some teflon paste , same idea as the perfect seal mentioned . Don't over think it...Just found it strange when I saw one go all the way through
