I have recently installed a new engine and took it out...wot is about 3500 rpm and slow out of the hole to get on plane...my prop is a 14x19p 3 blade aluminum...it was suggested I drop pitch...16 was the suggested. Any thoughts or is that right
as stated a 15, but that is so low in pitch and you would barely be getting into proper rpm it makes me think there may be others issues as well.. . Like wrong drive ratio.So in your opinion what should I drop to
I would do the tune and verify the tach first then see where it lands wot rpm wise Before buying a prop.I will also get a 15p...I am having a professional fine tune the engine
These came with the petronix ignition
