yes, best money you can spend.I haven't got one...temp gun right
These all look fine, not unusual to have diff between the two manifold sides. Elbows get raw water regardless of thermostat being open or closed o they should be cooler.So here's my findings with the temp gun. Ran up to temp...hx 170...manifolds 170ish..few degrees different from side to side...elbows were 95..100...block 150. This is running on muffs...I will check it all next time I ead out
