Ford 302 thermostat housing
Jakem
Alright...so I cannot find the proper stat housing anywere. I am going to have one made and wondering about the bypass outlet. If I have it put on to the new housing do I just run a hose of a port in the water pump
Jakem
It's closed cooling and only has 2 pipes. One for each hose from exhaust manifold
Jakem
The issue is also room...the one in diagram is skinney and not like a block like the other
Jakem
I've tried finding one and also on here. It seems to be the most elusive part on the planet. I'm done to making one and wondering about the bypass. I will weld one to flange and run a hose from water pump to it...sound right?
