Ford 351 H/M
vrod2002
I am swiching out the crank raw waterpump to belt driven which moves the alt to the left side. Pulled these parts of a 302. Had to shim behind the crank pulley to comp for the "hearst" style motor mount,plate that bolts between the circ pump and the timing plate.Everything else lines up but the brackets for the alternater seem to be different length and config for the 351.Anybody know of a diagram for front of the motor aq 240a's,glastron,inmar? or where to get the correct alt brackets? Thanks Barry
tommays
Re: Ford 351 H/M
all the around 1977 to ? Correct Crafts used the 351 with the belt driven pump and alt mounted like you are trying to due you may be able to find help here<br /><br /> http://www.planetnautique.com/ <br /><br /><br />tommays
mercrewser
Re: Ford 351 H/M
or better yet, WWW.Correctcraftfan.com Come on Barry, you know better than that. I thought Lee was your uncle? :D Let me know if you see any Correct Crafts for sale. You Ford guys :rolleyes:
